Ball joints
hoop0069
kent
mercedes 2006 e280cdi w211
Hi, Sadly car failed mot front suspension had excessive play in lower suspension ball joint nearside, does anyone know the part no. cos eurocarparts has 2 options for this part which seem completely different.....many rhanks
Can you provide some more info about the car - all we have to go on is 'mercedes e280cdi'?
If it's a 211, the Lower ball joints are pressed into the hub, the lower forward ball joints are all part of the thrust/suspension arm.
Hi, its the w211,i beleive its the one pressed in the suspension hub,its just a question of ordering the correct part, there seems to be 2 on the eurocarparts website....thanks again
The one you are talking about is this one:
| Car PartsRetailer
Needs a special tool for removal and fitting, about an hour to do one.
Tony
Thanks for the prompt reply folks, much appreciated
