greyboy
Hello, my car is a 1998 c180 sport estate, 120k miles. At the last MOT i had a warning about one of the lower ball joints.
Both sides are knocking over bumps so i will renew both. However i'm not sure which one it means. There is an upper one which is part of the upper wishbone, then a lower one which is double-ended then the lowest one is actually a track rod end.
Does anyone have any ideas? I could always change the lot as they aren't expensive from Eurocar parts. I have changed ball joints on previous cars is there any inherent problems with the c180?
