Gordon1956
i have a faulty drivers side headlight, bulb is ok, ballast unit under the wing has corroded to the point there is a hole in it. I suspect it is knackered but thought I could swap the ballast unit from the passenger side over which would prove the fault. Problem is I can't find the ballast unit for the passenger side. Someone give me a clue?
