Veni
Hello all.
After each start the engine, at intervals to 35-45 seconds, note the response of the system BAS.
Once, for a very short time, with different intensity - from the sound of the response to a sharp breaking.
Effects noted in both - the movement and stay.
The lights on the dashboard ABS, BAS does not light up.
What I've done so far is:
- Checked charging voltage of 13.3 V, ACC battery - new - 2 months.
- All contacts that are relevant to the ESP/SPS/BAS control module - N47-5, are checked and sprayed with a contact spray;
- Changed the brake light switch;
- Changed the BAS diaphragm travel sensor;
- Checked all voltages and switching, as described in the Star Finder - WebETM;
- Diagnostics with Star Diagnos - no errors.
Please advice on what else to check to fix the annoying problem.
The car is S210 E300 Turbodiesel wdb2100251a598975
Thanks in advance for answers
Venelin
Venelin
