Hello All,
I've recently had all my pulleys changed, including a new clutched supercharger pulley.
All was fine on the day of install and test drive. However, next morning I got a really bad squealing noise coming from the belts.
I sprayed a little squirt of WD-40 onto the belt and for a split second the noise stopped
This noise also stops once the car is fully warmed up.
I took off the supercharger belt and the noise was still there. It appears to be coming from the pulley that is mounted onto the belt tensioner.
I took the serpentine belt off and checked all pulleys by hand and no issues appear when spinning or moving laterally. Smooth and no grinding. The tensioner itself moves smoothly when I rotate this
The belt itself, is original but I can't see any cracks or anything else of concern so am baffled. Possibly the belt has stretched? but not sure as it was fine with the old pulleys, which by the way were all shot.
Any suggestions or ideas?
I have arranged at some point to change the tensioner, but in the mean time will replace the belt.
