I have a w212 eclass (pre facelift) with bi xenon lights. Recently notice the headlights were very poor and sure enough there was a message that right hand dipped beam faulty.
Checked relevant fuses and they were OK so naturally assumed the xenon lamp had blown after all they were originals and car now 11 years old.
Ordered new pair of xenon D1S lamps and spent a frustrating ½ hour fitting the right-side one only to find there was still no light . . . .
Read back actual values for right xenon headlight and supply voltage only 3.2v compared to 12v for left one. Further investigation traced the supply voltage to the thick yellow wire on the headlamp connector. Measuring directly at the connector also getting 3.2v although very occasionally flickering to 12v?
Am I correct in thinking the fault is not in the headlamp unit but what supplies it?
Where does the supply voltage come from?
