MR08AMG
- Jun 19, 2023
- Location
- hertfordshire
- Mercedes AMG edition C300 premium coupe & BMW M24Oi
Hi all I have read the tires chart on the thread but unfortunately it does not answer my question/ worries. I was advised from the lad at Kwik fit to make sure and check with MB forums community considering the vast experience here of doing similar upgrades on tires.
my C300 AMG LINE PLUS EDITION tires spec:
Front:
Pirelli P ZERO/ MOE/ PZ4/ RUN FLAT
225/40/R19 93 Y
Back:
Pirelli P ZERO/ MOE/ run flat
255/35/ R19 96 Y
I want to increase tire width by 10 mm taking it to 265/35/19 on rear (being a rare wheel drive BHP 320 & not a 4MATIC) to increase the rear end grip and for bit more protection on the rims as well as upgrade to 245 on the front from 225 so 20 mm increase so no more understeer in the wet! I hit the tire last month at corner while turning and front tire tore a bit. The rims are 19 inches and aspect ratio is 40 in front and 35 at the rear so we we not changing any of that, keeping it all the same as it is just increasing the width.
Now quickfit technician we did a quick check turning the front wheels full rotation either side and it appears enough room so with bigger tires rubbing on wishbone should not be an issue, gentleman at quick fit who seemed quite knowledgeable assured me. He said that you can order in and we do a fitting and test and if any issues we can take out the new one and put old one back but hopefully it will be all ok which was quite reassuring guarantee in case they dont fit! But before ordering in he advised to check on forums as others have done the similar upgrade to absolutely make sure we good. So any advice form the rich experience here would be most helpful.
The tires I am looking to order are Merc OE x 4
Front: Michelin Primacy 3 245/40/ R19 98Y XL
Rear: Michelin Pilot SUPER SPORT 265/35/R19 (98Y) MO1
Another thing they are NOT MOE so the run flat for 30 odd minutes is not there but I am not fussed about that. The car is only used for daily locally commute to town, gym etc. If I am going long distance than M240i is used. Does merc cause any issues over it when taken in for servicing I wonder as I have a service contract with them ? They refused to put bigger width quoting me the standard manufacture line that they will only put exact same ones where as a new c43 is being sold today has the same rim and aspect ratio as my c300 and comes with bigger wider wheels so in my research as much as I could find it wont be an issue at all just increasing the width by 10 mm at the rear and 20 mm in front.
Please could u advice if you got similar upgrade and share your experience any issues etc. Thanking you all in advance. Cheers all.
Front:
225/40/R19 93 Y
Back:
255/35/ R19 96 Y
