Brian k
- Jul 16, 2017
- Location
- Glossop / Stockport
- E Class 220d W213 Premium Plus Package
I use the hold function all the time too and have never had brake judder. Maybe I’m just lucky.
Maybe I'm just unlucky.I use the hold function all the time too and have never had brake judder. Maybe I’m just lucky.
It's never juddered under firm braking, but light braking from 70-50mph it was awful at times, plus when just creeping along in traffic I could feel the brakes doing a sort of grab and release even with a fixed input on the brake pedal. It doesn't do any of that now.
The Hold function was/is very useful, might try using it again and see if the juddering returns.
You are doing it wrong, you just have to tap the brake pedal while stationary and it will hold.I had a rental w213 e220 with juddering brakes. Very similar symptoms. To me it felt like a slightly warped disk. I'm not sure if hold function was to blame but holding hot pads against the disk can create a hotspot. I wouldn't stand on the brakes for that very reason.
I tried hold function on my car today and was surprised by how hard you have to mash brake pedal to activate it. It is easily 5x of my normal effort. I only hope this doesn't translate into actual hydraulic pressure... Hold is not for me.
I think its more to do with the speed you apply the brake pedal rather than the force- a rapid tap does the job rather than a slower application using great force. These new intelligent braking systems can anticipate braking requirements. [BAS] At higher speeds if the system anticipates from pedal movement that a greater braking effort will be required it boosts the brake application force independent of pedal pressure to maximise braking effort. I reckon its the same "pedal speed" facility the system uses on both occasions .thanks, I'll stick L plates and try again tomorrow![]()
Pickup on the discs is possible particularly if non standard MB pads are used but another possible candidate are sticky calipers. IIRC most Mercedes have sliding calipers on all 4 wheels, not sure on the E63? If the caliper movement on its pins were to be stiff through lack of grease this might be enough to give a similar effect?I had a rental w213 e220 with juddering brakes. Very similar symptoms. To me it felt like a slightly warped disk. I'm not sure if hold function was to blame but holding hot pads against the disk can create a hotspot. I wouldn't stand on the brakes for that very reason.
I too don't quite get it and was convinced that the discs were warped. However after reading the thread that I linked above (page 1), and then taking the actions I've described, the brake judder problems have gone away...Why would the HOLD function cause brake judder? What’s the difference between the HOLD function and you holding the brake with your foot?![]()
Good luck.thanks, I'll stick L plates and try again tomorrow![]()
Ditto...I'm not so keen on the auto braking ,where you actuate it by pulling cruise stalk towards you, feels as the brakes are dragging when thats on.I use the HOLD function all the time - living in a town - and haven't had a problem. In fact my previous two M-B's (both C-Class) didn't give any trouble.
Don't think the issues we've experienced with our S205 were down to warped discs. Have had those before and they don't go away with a few firm braking events.Warped disks can occur on any car. It’s certainly not specific to the Mercedes hold function.
It’s usually caused by keeping the brakes on after heavy braking. For instance coming off a motorway junction and braking hard for the roundabout. It can be eliminated by making sure you leave some extra space after your big stop to roll forward before finally coming to a halt.
If the bulk of your driving is urban, it’s unlikely to cause you a problem.
We are both pretty light on the brakes generally and hadn't really done any big stops in the car when the juddering first appeared, but I take your point. If I could be bothered, I'd change the pads (and maybe discs). As it is the braking is fine now that we stopped using Hold, which might be some sort coincidence though with what I'm not sure.Yes, it may well be pickup from the pads but it will be caused by the same thing. One big stop and then holding the pads against the disk.
An extreme example is if you go on a track day and they will advise you not to use the handbrake when you come into the pits. The reason is that on a track your rear brakes can get hot - much more than usual road driving - and if you have the type of handbrake which acts directly onto the rear disks, you can stick the pads to the disk...!
They should have put "hold" function on a button, that's all i'm saying .....
why not? They should copy Audi's. They copied iPod instead with brake pedal action, not good...What, like an electric handbrake??
