steveskeggy
- Jul 4, 2011
- S55 AMG
Hi.
I have a problem with my 2003 S55 AMG.
It has occured since getting the car running after 2 years rebuilding the engine top end.
The brake lights are illuminated constantly when I turn the key to position 2 (Dash lights on), or with the keyless.
It will also not come out of park, unless I tap the top of the selector with a rubber hammer.
I have replaced the brake light switch, to no avail, I tested the old switch with a multimeter and a wiring diagram of the switch from the web, the switch worked fine.
I have tried the new switch unmounted from the pedal bracket, the result is the same, In fact, if I disconnect the switch, it is the same.
It seems a bit strange that the lights are illuminated, which would point to the pedal being pressed, yet the selector wont come out of park which would happen if the pedal was not pressed.
I have the usual BAS ABS warnings come up, but I cant really drive the car as yet, because there are no brakes pads in it, because the discs need skimming.
In another post of mine, about a different subject, the rear SAM was mentioned if it wasnt the switch, this is my next move, even though its not throwing codes.
I have ordered a rear SAM just in case, if it is not the SAM then its always handy to have a spare.
Anybody think of anything else that it could be?
