Brake master cylinder?
tmaoahthfte
East Kent
W220 320CDI Previously W210 220 CDI, W202 C200T KOMPRESSOR
Hi all, changed the brake fluid in my w210 recently, the fluid that came out of the front nipples was dirty, the rears came out clear. Would this be a sign that the seals are starting to go in the master cylinder? The pedal feel was slightly spongy before, feels quite a bit better now.
It doesn't really tell you anything about your master cylinder seals.
The fluid in the calipers doesn't move much and does tend to come out a bit dirty.
When changing fluid, you pump out any dirty fluid from the caliper, so the first fluid that comes out through the nipple often looks like this.
