Haven't sorted the stalling problem as yet, but fiddling with the ABS sensor on the wheel makes the light go out. When I find a breaker-bar long enough to undo the wheel nuts, I'll try to remove the sensor, clean it properly and sort the wiring.
Another problem I've been trying to sort is a vibration at 60mph+. It's just about detectable at 50mph and gets more severe the faster you go.
From topics on here, I know there are a few things to check, but I'm not sure what's the best order!
-Wheel balancing (it has four brand-new tyres)
-Propshaft centre bearing (or from forum searches the rear diff?)
-Suspension bushes (the nearside front wishbone bush looks a little dated, but doesn't move at all if you give it a good pull...)
I've also given it a thorough clean inside, under and out, and checked all the usual rust spots.There's a small amount of corrosion on the front inner wings by the ABS gubbins and washer bottle (to go with the corrosion on the front outer wings!), but everything else (rear arches and jacking points) seems to be super solid! Some liberal application of POR15 and Waxoil next week will hopefully see to the stop of any further rust.
I dare say that having some sort of workshop manual might help me to sort all of these little jobs without having to search the forum - is there one online, or am I best looking for a Haynes?
