brown mirror
Voyager
the drivers wing mirror has gone a browny colour on my s210 3320cdi estate 2001 - seems to be behind the glass - can you help ?:cool:
Water/dirt has prob got in between, try ebay.
Good Morning
The mirror glass going brown is a sign that the auto dimming feature of the mirror has failed.
Only option is to replace the mirror glass, you will be shocked with the price!!
Some have fitted non dimming glass in place of the original to save money.
Options on replacement might have increased though as mine failed about 6 years ago so there may be factor part replacements now.
Some say that the liquid if it gets on your paint can damage it. Cant comment on whether this is true.
Hope this helps
230k
230k is spot on. And you will be shocked at the replacement price. Mine went on my SL, I got a cheap replacement from Nick, iirc it was about £100. Believe me, that was cheap!
You can carefully remove the outer glass...leaving a mirror behind. This will do everything except dip...
I got replacement glass which is also heated from eBay for £15. You don't really need the dimming as they are tinted anyway.
