9. On a more general note, think twice if you want to buy a car fitted with a BLUETEC engine and the infamous AdBlue system...
Thaks for the tips.
Re. the adblue system.
You are correct. That is why my plan is to keep the car under warranty as much as possible and then sell it in 4 years time. Inchape warranty is for car les than 10 years or less than 100K. Mercedes :10 years or less than 120K
The warrnty will cost me between 400 to 700 a year.
The inchape extended warranty could work out cheaper. I have checked the warranty document and from what I understood the adblue system is covered:
What is covered
Covers most major mechanical and electrical parts against breakdown or failure
Helps protect against the costs of replacing parts and the labour to fit them
No limit to the number of repairs
you can claim for, up to a total of the original purchase price of the
vehicle
Temporary hire car while warranty repairs take place
Up to 60 days’ warranty cover while the
vehicle is in the EU or the EFTA (European Free Trade Association)
The warranty can be transferred to the new owner if the
vehicle is sold privately
For vehicles up to 10 years old and less than 100,000 miles when bought
The new improved warranty cover
Our new and improved warranty now also covers the following (if
your vehicle has them).
Diesel particulate filter
Parking sensors
Infotainment system
LED lighting
Wiring harnesses and connections
Catalytic converter
Exhaust systems (when repairs are needed due to sudden failure, unforeseen circumstance)
Airbags
Oil leaks
What is not covered
This warranty does not cover the following.
Body parts such as strikers, hinges or any part which may need adjusting from time to time
Body panels, paintwork or glass
Interior trim, seats and seat belts
Recharging the air-conditioning unit (unless this is needed as part of a covered repair)
Replacing brake parts due to wear and tear or overuse of the brakes
Renewing any clutch parts due to wear, incorrect adjustment or misuse
Clearing fuel lines, filters, throttle body and pumps and repairing damage caused by using incorrect or contaminated fuel
Replacing batteries (see note to the right), bulbs and wiper blades, balancing and aligning wheels, replacing or repairing wheels and tyres
Repairs that are needed as a result of damage to the
vehicle, or parts of the
vehicle, caused by water
Any damage caused by frost or lack of antifreeze, an accident or negligence
Radios, cassette players, CD players or any other in-car parts not fitted by the manufacturer
Exhaust failures that are not due to sudden or unforeseen faults to any weld or joint, modifications, parts added after
you bought the
vehicle or parts not fitted by the manufacturer, accidental damage caused by speed bumps or kerbs, or any type of wear and tear or corrosion
Normal maintenance, servicing and replacing items such as spark plugs and plug leads
Weather strips and body seals
Any damage to or loss of parts that are not directly covered under this warranty
Burnt-out, sticking or pitted valves
Damage resulting from the failure of a timing belt which has not been replaced in line with the manufacturer’s recommendations (
We will only cover this damage if
you can provide proof that the timing belt has been replaced in line with the manufacturer’s service schedule.)
