Assuming you have the 4 speed hydraulic box there are no error codes to be read unfortunately. Sounds as if something terminal has happened. There is a fault on these boxes known as the B2 PISTON FAILURE which results in total failure of the forward gears while reverse remains OK. The other possibility is the box was over/under filled with fluid during its last service. The 4 SPEED hydraulic box of that vintage uses Dexron 2 fluid which is pretty standard stuff so I don't expect a fill with the wrong fluid is at fault. First thing to check is the fluid level is correct. There are specific instructions for this which must be followed exactly to get the level correct. The fluid should be clear probably a red or yellow colour. If its dark brown or black and has a burnt smell that's a bad sign. Get the car looked at by a local reputable autotransmission specialist ASAP.
