c180 cutting out
martinsmith43
Hi im new to this so bare with me, I have just purchased a c180 1998 and while your driving the car will cut out and the lights come on on the dashboard , the car then will not restart,it will turn over but its as if the fuel is not getting through i think , if you leave the car for ten minutes it will start and maybe run for the rest of the day and then all of a sudden do the same thing, thanks for any help.:crazy:
When it wont restart, have you got a red & a green light flashing on the interior mirror ?
As jay says CPS - not restarting when hot is a classic symptom. It will probably get gradually worse.
chek the battury on the key fob
no, everything seems to be okay. i have just gone back to the car because it cut out at the bottom of my road and it has started first time .
sorry to be a pain but is it a big job to change the sensor and how much are they to buy, im pretty handy as im a maintenance engineer, cheers
About £80 I think from Mercedes - possible cheaper elsewhere, try eurocarparts.
Part no 8 here - not sure if that's the right part no for your car but location should be the same. If you navigate from here you can find the correct part no.
thanks for your help
