C180 Engine Rattle
Comcastle
Kent
W202 C180 Sport
I've searched around on the forum and think I know whats causing my rattle noise, however I'd like a confirmation if possible.
When starting from cold, I get a tappety-rattle from what sounds like the front-top of the engine. Classic diesel sounding noise. I've had very similar noises on two previous cars that had VVTI rattle.
This is most noticeable when in 'Drive', as when I put it in 'Park' the noise will disappear, and the noise will also disappear when you increase the revs a bit. The noise has also disappeared if I switch the Air/Con off. (Although that is not always the case)
Once the car is warm, the noise is no longer there - she purrs quietly.
Now having looked around, I'm suspecting the tappets / hydraulic lifters, but when factoring in the A/C sometimes having an effect over the noise, perhaps the clutch bearings are going on that?
Any pointers would be appreciated.
It's the hydraulic tappets they need to be changed noting to worry about
Thanks horgantrevor, will start preparing for that fix in the near future.
@ NW_Merc, I'll update my info box with a bit more detail, 'C180 Sport' does lack a bit of focus!
