My C180 normally has a temp of just under 80 on the motorway, or around 85 - 90 in stop-go traffic. Yesterday I was parked up with the engine running for about half an hour, and I noticed the temp rising. It went to about 100 and I though hmm never noticed that before! Then it went up to 120!!!
So I turned the engine off.
Restarted and drove off about 5 minutes later - temp still on about 120 on startup, after driving less than 1/10th of a mile, the temp was back to a more normal 90. I saw the needle moving a bit erratically at this point and then setting around 90.
The radiator looks ok, no obvious leaks, the hose to the radiator was hot when the engine was hot as you'd expect. Drove it around today and it never went above 90. Sat around for about 15 mins with it on and it never went any higher.
Just a glitch? Something to worry about? Thermostat stuck? Sensor knackered? What should I check?
Thanks!!
Thanks!!
