greyboy
Dear All,
I have a '98 C180 Sport Estate Auto, 112k, FSH, with the last service 7k ago inc new air/fuel filters and spark plugs. Due to poor performance a new MAF was fitted about 12 months ago, still the same so the garage then fitted a new hydraulic selector unit in the gearbox (both under warranty so no cost to me). Still the same so they said it could be the gearbox ECU under the passenger seat ! Enough willy - nilly component changing so i said goodbye. Genuine Benz garage too.
I have had the car 21 months now and it still has the same symptoms. Starts fine hot or cold, gear change fine up and down,runs smoothly and quietly if pottering about however if you want to go fast (yes, i know it's a 180),it is very reluctant to rev over 4k rpm and hesitates/hunts. When revved in Park, the rev limiter cuts in at 4k rpm, not near the red line. Is this normal?
I have put injector cleaner in a couple of times and today thrashed the car holding to the red line in 2nd and 3rd. It seems slightly better. Has anyone any idea what this fault could be? What else should i be looking at?
