C180k Coupe Brakes....
Yogi bear
Lincoln
W203 C180 Kompressor Coupe
Has anyone have any idea of the dimensions? I'm wanting to buy drilled and grooved front discs and pads from a C32 AMG...the dimensions of those are as follows -
Front Discs Specification:
Vented - Studs 5
Disc diameter 300.0mm
Disc thickness 28.0mm
Overall height 46.5mm
Centre diameter 67.0mm
Minimum thickness 25.4mm
Question to you fine people is....are they going to fit a W203 C180 coupe Kompressor 04' facelift?
It will be fine.
I think you may have to have 17"wheels for them to fit.
Make sure the front hubs are free of corrosion before fitting otherwise you will warp your discs.
Thanks for that info!
They're only 300mm discs so that's only 11" plus the calipers...call it 13"
