Lyserman
Quick recap:
EML came on, Downstream O2 sensor fault, replaced.
Failed MOT on emmissions, lambda low, running rich & stinking of ammonia from the exhaust.
I have renewed the check valve and perished pipework under the inlet manifold, very cramped behind there but doable without removal of the compressor. I could do a mini write-up if anyone is interested.
Between ordering the pipework parts and their arrival I temporarily jumpered out the broken check valve and perished pipework and took the car to a local indie for a diagnostic. Said what I had done so far and afterwards he said it was P0172 (self adaptation is too rich and P0137 downstream O2 sensor short circuit to ground).
He said either wiring fault or ECU.
I used the plug from the old sensor and checked all four wires for continuity back up to the ECU plug, all 4 had good continuity but the thicker red wire leading from the sensor sockt end has a resistence to ground of 431Kohm whilst the remaining three are in the 45Mohm range.
Before I start pulling the loom to check for faults does anyone here know if the 4 wires to the sensor just go straight back to the ECU plug or is there somewhere else it travels to enroute?
Sorry for the long-winded post but had to put in the relevant details.
Thanks,
Tony
Thanks,
Tony
