drivebyabuser
Back to MB ownership in the shape of a 2012 C207 250 CGI. Its all very lovely actually, however the inside rear light (the one on the boot lid) has stopped working. The unit is fine - Works on the opposite side connector, so am troubleshooting. Stripped out the carpet from the boot, and had a fiddle with the wiring looms. With a little wiggle it flashed back to life for a brief, wonderful second. Assuming a broken wire obviously
I have taken a meter to the non working lights plug and got some weird results - 12v from the brown "neutral" wire and nothing from the green and white striped (on the opposite working light brown is neutral and the corresponding green wire is showing 12v) Does anyone have a wiring diagram for the C207? Or any idea what each wire should be pumping out what voltage wise?
