Fastcar155
Happened to me many years ago , I though the macaniic wanted the car for himself.WOWI just took the word of the technician where the MOT was done.
How do I find an answer to that thunderbolt of yours?
I have actually seen it work . Some years back I popped into my mates MOT garage , at the time he was a very small operator and if I remember correctly it was a Friday early evening.Never done an Italian tune up, how will thrashing an engine clean it ?
It wouldn't get any hotter and the fuel pressure through the injectors would not rise to clean the internals, so does it do anything ?
Asking for a friend.
The cleaner made the difference - not the thrashing.I have actually seen it work . Some years back I popped into my mates MOT garage , at the time he was a very small operator and if I remember correctly it was a Friday early evening.
POS small diesel van that was on it's last legs and possibly last MOT was not quite getting through tailpipe emission test. As the van belonged to his mate and it was getting late he asked me to mind the shop for a few minutes while he took the van for a 'burn' , he emptied the fuel filter and filled it with some sort of cleaner out of a sealed can and set off at speed.
I am not sure of the details but I believe the MOT test times out if the vehicle doesn't pass emissions within a certain time frame. Either way he was back in no time and the van passed (just) .
He knew the owner and that the van was only used on short journeys around town so maybe he knew he had a chance of success. I do know that now his business is much bigger and snowed under with work 'Italian tune ups' are no longer on the menu.
Not sure they work with more modern engines these days.
That’s my reasoning as well , my diesel is pretty much always in S mode .It does.....lots of people poodle about in there dervs and the air flow is not enough to blow it through. A good thrashing....which is usually accompanied by a decend black cloud from the exhaust if not revved hard recently just blows it all through and improves air flow. My Jeep (cat but no DPF) needed this before every MOT or it would fail. My ALFA failed on emissions a few tests back....I gave the tester permission to thrash it a mile up the dual carriage way......passed easily after that. I do it before every MOT now!!! Dervs dont like slow driving....modern ones even less so.
Not necessarily, my licencing area have moved away from twice yearly compliance/MOT test to just the standard yearly MOT, saves money for the council although they still bill the driver the same.And gets an MOT every 6 months ....![]()
Yes it shouldn’t allow dirt through the dpf .But surely it shouldn't smoke at all, isn't that why the DPF is fitted ?
Probably one of the idiots who have removed the dpf from their car?But surely it shouldn't smoke at all, isn't that why the DPF is fitted ?
Check the Datacard for option 474 DIESEL PARTICULATE FILTER
Its a Peugeot!
This is the way we always de coked our cars in the carburettor era, never had any issues. Iirc it was the thermal shock that did the trick.Re: Fuel additive. I came across this amusing post which may be BS!
"Back in the early 80's while working as a mechanic, my boss did an experiment. We pulled heads off a daily driver and inspected the carbon build up. We put the engine back together and ran it up to temp. He then slowly poured cold water down the carb at about 3500 rpm. He poured about a cup, maybe more (I don't remember, its been a while). At the end of the day when the engine was cool enough, we pulled the heads off, most of the carbon deposits were gone."
