Smokin..o0O
- Mar 8, 2005
Hi all.
Recently had a few problems with the wifes car.
2001 C220 CDI.
In the last 2 weeks had trouble starting the car in the cold mornings so had a new battery fitted and the fuel line between the lift pump and fuel filter, as there was air constantly visible.
The car has been great since these jobs were done. Starts first time no matter how cold it is, and no more air in fuel line.
This morning however, the car wouldn't start. The ignition "energises" when the key is inserted, the steering lock disengages, but turn the key to the "start" position and nothing happens.
My fist guess was the inhibitor switch but I haven't checked that out yet as I can't find out where it's located, but I think there may be something else at fault.
I checked the connector at the solenoid with the key at the start position, and there is no voltage reading.
I took 12 volts to the solenoid connection with the ingintion on and the card started.
It was raining pretty hard and there were leaves on the windscreen so I switched the wipers on to clear the screen but the wipers didn't work
Lights indicators, heater, electric windows and everything else weems to work, just no wipers or starter motor.
I have made arrangements for someone to look at the car, but as I can't get the car to him, it's going to take a few days before he can move it, and the car really is needed.
If anyone here can think of anything that might be related to this issue, and that a DIYer can check out, I would be forever grateful.
2001 C220 CDI.
