when turning or going bumps i get a loud rubber noise almost like rubber compressed ?horrible ? just wondered if there was any suspension parts that go on a regular basis before jack it up tomorow ? thanks
The lower ball joints and the camber and castor bushes are common on a w202.
If no wear in these bushes, get the cars geometry checked as I had a similar issue on mine and this solved it.
cheers andy and you were right ,ive just had the car 4 wheel aligned and it is all over the place ,infact that bad they would not trackn it up due to massive play in all ball joints,play in botton arm bushes and one of the top arms in the strut top is about to fall off ,ive just ordered it all so it looks like a busy weekend ,they told me it should feel like new when ive replaced it all and had it tracked up? thanks for the help much appreciated .
