E400D Coupé PP Cavansite Blue, Mini Countryman SD , Cayman
I‘m looking to get a jack puck that fits my car , 2019 E coupe
Any sources ?
Googling isn’t bringing anything up , maybe I’m not searching for the correct name ?
Any sources ?
It is made of rubber in order to give you the strength to lift but also a small degree of flexibility. The bumpy section below the pad is part of the Trolley Jack NOT part of the Jacking Pad. ALL sizes are approx.
I bought a couple from Powerflex, as they are properly moulded out of robust material same as the bushes and I'm more sceptical about things carved from hockey pucks. About £10 each. There are various types, so check the fitting against the jacking point under the car.
