Hi All,
Just replaced my rear brake pads on my 2001 C240 tonight. Noticed that OSR bleed nipple leaking fluid, seeping very slightly. (before the replacement operation started). Tried to tighten bleed nipple, used deep socket, but corners of hex rounded off. Rust. Will order new bleed nipples tomorrow x 4.
Should I replace brake fluid (56K miles) and is there any set procedure for bleeding. ie, furthest away wheel cylinder or closest first ?
Also, you technical guys, any idea of how much fluid and make is required for complete replacement ?
