classiccarzone
- Aug 1, 2012
- Location
- Ireland
- S203 CDI estate; S204 Cdi Estate,CL 203 X 2; Daimler V8 250 X3
I have just sorted this problem on a 204. Replaced the diff sensor and the code kept coming back and the soot content still reading high and increasing.
My back pressure was well within the limits; differential pressure was excellent but soot content and fill was reading high.
When you go into the icarsoft regen section it will say that it is not able to regen and direct you to a section where it does an automated examination and comes back with the real results-in my case 2.8% fill and .6g soot.
It will then allow you to do a forced driving regen.
I chose to put it on a Snap on diagnostic which still showed a problem with the diff sensor. I told it to renew the DPF and everything went back to normal.
Just fitting a new differential sensor will not cure the problem unless you do either of the above.
