Pete, a vac control solenoid will not work, you need a vacuum modulating valve (aka vacuum transducer) that can deliver variable amounts of vacuum. Vacuum solenoids are on or off.
These transducers are controlled by PWM, not variable vaoltage, and the voltage feed is 12v.
