All
I need some guidance please.
C270cdi saloon auto.
I will try and give as much info as possible
116k miles with good history.
Car starts fine cold or hot.
In last 1k miles all injectors have been replaced as they were shot and I just changed the lot.
This issue was present prior to injector change.I had two leaking and others were worn when tested so I just bit the bullet!!
New MB seals and bolts.
New fuel filter.
New glow plugs.
I have no errors regards glow plugs ie coil remaining lit on cluster etc.
As stated car starts immediately
On initial start in morning the engine is noisy and by this I mean diesel clatter.
Once warm the engine is smooth as silk and very quiet especially for a diesel.This can take 10 miles plus.
MPG is fine. It will do high 50s on a run.
If I leave car for 3 or 4 hours and restart the engine is quiet and smooth.
Terrible noise when started again next morning.
Now I have noticed that the car takes an age to get to temp.
By this I mean will sit at 60 degrees or less for an eternity .To make this rise anymore you need to let it idle stationary and then it is fine.
If your journey was on a motorway immediately from starting it wouldn't move over 60 degrees if that makes sense.
Could the high pressure pump be at fault??
Is the thermostat shot and in turn wrong fueling info is being sent and causing diesel clatter??
This is driving me mad!!!!!!!!
The car idles perfectly.It does not miss at all.
Pulls strong
Can anybody give any advice through experience??
I want it sorted just need a direction to investigate.
Many thanks for any help you can give.
Any info anybody needs just state what and I will post it.
I have tried to mention anything relevant.
John
New fuel filter.
New glow plugs.
Pulls strong
John
