Just had the inlet port shutoff motor replaced because of the common oil leaking from the turbo problem. Still showing the following current codes. Does anyone have any idea what cause these.
2530-002 Check component M55(Inlet port shutooff motor). Short circuit to ground
2527-002 Check component Y27/9 (Left EGR positioner). Short cicuit to ground
2376-001 Check component N3/9(CDI control unit) Actuation M16/6 (Throttle valve actuator) Voltage is too low.
Any help greatfully received
