C63 w204 - H&R lowering - issues?
Ashventini
Daventry
C63 AMG 507 Edition
Hi there. I've got my w204 with a H&R lowering kit... dont know if they come with different lowering heights or they are a standard drop like 20mm, the previous owner fitted the H&R's. I have had the front driver inner wheel arch catch on something - looks like maybe the tyre caught when on full steering and possible a pot hole together - anyone else had this issue? Is it just an accepted risk when lowering the car and how unlucky does one need to be the have the tyre catch?
Has anyone lowered the car and then reverted back OR perhaps compromised and maybe increased the ride height slightly of the lowering springs (sounds odd) but you get what i mean? I dont know how low mine is as i didnt fit them. I can add a photo if that helps. Maybe someone went right to the lowest height offered by H&R..?
Your car looks lovely 👌🏻
I’d say it’s just a risk of lowering the car. Lowering the car inevitably increases both the likelihood that the tyre will catch and the impact if it does catch. The lower you go, the greater the risk. You could accept the risk or switch back to standard springs.
Thanks. :)_
is there an intermediate option? such as adding a spacer to increase the ride height a bit or maybe a different lowering spring that is a little higher than what i have now (but still lower than standard OEM)?
Thanks. :)_
Almost certainly, depending upon how much your existing springs have lowered the car. You may be able to find some spings with a smaller drop, or you could consider height adjustable suspension which would replace both the springs and dampers. The latter would give you more control of the ride height but of course costs more too.
I dont know how much its been dropped - just that its H&R. I was hoping by sharing those photos someone would chime in and say - looks like its been dropped 20mm or xx mm and you can increase it slightly by replacing the springs with these.... (adding a link)
The springs will have a no on them and then you will know by how much its been lowered ,also be aware that you will chew through front tyres this is my old 1 standard
Would you know where to shop or any links?
You need to see the part numbers for the range of spring pads for your car. Put your VIN into an EPC like thisone:
Then find out which pads are installed and but thicker ones from MB.
When my springs were changed, I gave the garage a complete set of all spring pads (4 thickesses for the front and 3 for the rear, so 14 pads in all) so they could choose for the correct height. Some say that my Sportline is a little high, and it might be. But with the roads around here that's no bad thing.
RayH
RayH
Thats a massively helpful link. Thanks. However What part on this is needed? I only see the upper and lower shims. Is that what is needed? There is only 1 part number for each - i dont see thicker options under the parts listed. Am i looking at item # 20 and 40 (shims)? I only see 1 option
