Came home on a flatbed :(
For what it's worth, i dont think that travelling in 4th for however long would cause any problems whatsoever (apart from excessive fuel consumption), i do, however, think that your problem was entirely due to the probability of an overfilled 'box.
The correct oil level is critical in the 722.6 'box as is using ONLY the MB oil.
{Edit}...Just found the article below, makes interesting reading....
Filled for life?
The 722.6 Automatic Transmission uses a special oil and is said to be filled for life. The oil can only be purchased through the Mercedes-Benz dealer using part number 001-989-21-03-10. A 722.6 holds about 9.3 liters and the fluid is sold by the liter. Checking the fluid is accomplished by breaking off the red locking seal located at the dip stick. the lock is replaced after the oil is checked. Use part number 140-991-00-55 for a new lock. There is no dip stick to check the ATF. You need a special tool to check the fluid on all 722.6 transmissions, part number 140-589-15-21-00. The oil level is a critical factor in transmission shifting. See Service Information 27A95105 for details. When you refill, or check thetransmission fluid level make sure that you check the level with the special tool and at the correct temperature. The latest information from Germany is that we should fill the oil to the MAX line. Not overfilled, just maxed out. This is said to improve shift quality. At normal level it is possible for the oil to form air bubbles. The increased level helps to minimize this. You might want to remember to try this on customer complaints involving shift quality before you replace any component. Along with setting the adaptation you would be surprised to see how much of an improvement you will see.
The Automatic Transmission fluid is said to be filled for life. We never specified who's life. (Yes, they actually wrote that in this!-DG) The transmission control module contains a program that keeps a running count of the "calculated" cndition of the ATF oil. (Note from Gilly-I believe this was deleted from the modules right around 2001-2002, not there anymore-DG) The factors that affect the oil are time and temperature. The counter is incremented with engine running time and incremented greater with higher ATF temperatures. The Hand-Held Tester (now SDS-DG) displays a numerical value that represents the value of the calculation. At some given point in time Germany will tell us (still waiting, evidently-DG) which number means its time to change the oil. For now there is no service interval for the ATF oil. If you replace a transmission you should re-set the counter back to zero to account for the new oil. If you are doing internal work and you are replacing the oil you should also re-set the counter. It is acceptable to drain the oil out into a clean container and reuse it, provided it was collected using the MB filter funnel. Remember to flush the converter and kines before installing the new transmission. You should also replace the converter if the transmission was HEAVILY contaminated with metal. Make sure you return the converter with the transmission to warranty. Fine metal particles in the bottom of the pan are allowed. (I think what they mean here is that fine metal particles are considered an "acceptable" condition, do NOT replace transmission, as you will see if you read on:-DG)
The Color of Money:
We have been conditioned to judge the quality of the transmission fluid based solely on it's color and smell. We have no way of judging the frictional quality. The rules have changed. (didn't Iaccoca say that too?-DG) The bright red color that we are all used to seeing may not be what you see when you look at the ATF in a 722.6. The reasons that the oil looks differently are as follows:
1) The oil may appear dark red due to the graphite material that the friction discs contain. This does not change the characteristics of the oil. Do not change the oil or transmission if the oil appears dark red or even if it has a yellowish tint to it. The color will change with time and temperature. As of 10/97, the manufacturer of the oil has agreed to put more red particles in the oil.
2) If a copper color is seen in the oil pan the bushings of the front or rear planetary gear set may be in the process of wearing out. Inspect the bushings and if they are defective replace the complete transmission. If they are not defective, then the transmission is repairable.
3) If a silver color is present in the oil it may be a clutch and steels moving up and down on the hub as they are being applied. This is normal! Use your best judgement here. If the particles are fine they should not cause problems as they will be trapped in the filter. The fluid could be drained, including the torque converter, and the lines flushed and the valve body should be disassembled and cleaned, replace the filter of course. This usually takes care of the problem. If you take the time to inspect and clean each slide valve for ease of movement and base position you will have a better valve body than a new one from spare parts. In more severe cases where the particles are large, then something is in the process of self destruction and the transmission should be either replaced or repaired. Don't forget to check the electrical solenoid valves. Shine a light through the top of it and see if it "leaks". If you drop the transmission oil pan (I think they mean "remove the pan"-DG) and you find yourself feeling like a miner panning for silver, or knee deep in a graphite colored mud, then it's time for a new transmission. You may have noticed that the new pans are painted black on the inside. The metal particles show up better against a black background as opposed to the previous unpainted silver pan. You must get used to seeing some metal in the bottom of the the pan, with this transmission this is normal.
4) Smell the oil. You know by now what burnt oil smells like. If it looks burnt, and it smells burnt, then its burnt.
Example: Try looking at the adaptation values for K3. If the numbers are high, then you have a K3 problem. If the customer is complaining about shift quality going in and out of third gear, repair K3.
5) Make sure you understand the complaint before you disassemble the transmission. Use the HHT (SDS now-DG) adaptation screen values along with the shift application chart to see which shift members are applied during your customer complaint so you will know where to concentrate your efforts when you disassemble. Remember to disassemble the transmission like a surgeon, you need to observe the condition of seals, rings, c-clips and shims as well as being aware of the potential for missing parts.
Repair or Replace:
Use the transmission oil pan as an indicator when deciding to repair or replace the 722.6 transmission.
The following pictures (sorry folks, I'm transcribing the written part only, no pictures-DG) are for reference as to which transmissions should be replaced and which should be repaired.
(picture shows a black pan with some small "dots" here and there-DG) This is a normal oil pan for a 722.6. The fine particles are normal. Do not replace this transmission.
(can't tell what's "wrong" with this picture-DG) The brass colored particles may be a sign of a bushing problem. This transmission may be repaired.
(can't tell by the next picture either what the problem is supposed to be, rotten copies!-DG) The metallic sludge indicates that there is a major mechanical problem. This transmission would probably cost more to repair than to replace.
(This picture you can see obvious copious amounts of metal shavings, a pretty good coating of it-DG) This picture also indicates internal damage has been done. This transmission would be replaced (as well as the TC and flushing lines and cooler, etc-DG).
peterchurch said:
I could be peaved about this, but I am happy that the garage took one look at it and sorted the fault.
Would I use them again? Yes, without a doubt!
Thanks for your support :D
I respect your decision and only you know just how competant this 'specialist' really is.
Overfilling any item can lead to problems as we are all aware that liquid cannot be compressed. Something will have to 'give'. Oil flowing onto a hot exhaust could quite easily be extremely serious. Luckily things went bang on a straight piece of road. I have seen more than my fair share of accidents involving innocent motorcyclists coming off their machines after riding over spilt liquids. Unfortunately they are not usually in a position to claim off the guilty party.
How does transmission fluid react with paintwork? Hopefully it will be similar to normal oil.
Fingers crossed that all your troubles are behind you,
Take care,
John
Old 722.6 info ?
Well, yesterday I went to a MB dealer to buy ATF oil,sump gasket and filter for my 1997 C-180 722.6 5 speed auto total £65. The items where in stock so I think this filled for life spec info is several years out of date, MB do change it.The dealer insisted that 6 litres was enough oil.Can anyone confirm this...Dieselman ?? I don't want to drain the oil and find 9 litres coming out !
adam
Filled for life?
The Color of Money:
Repair or Replace:
adam
Adam,
Never actually changed the transmission fluid yet on my W202 (it's on the list of 'jobs to do'), but IIRC it is ~ 6 litres for the box and ~ 3 litres for the torque converter.
Try a forum search - I think many people have 'been there' before.
HTH, :)
Will
Mine took 7,5 litres in the end. Problem was, mine doesn't have a drain plug on the torque converter, so conceivably some oil was still remaining in it. Steve did run the engine on idle with the car canted over on a jack to get as much out as possible; the first draining yielded about 6 litres from the box alone.
Really worth doing though; it's virtually impossible to detect the gearchanges now and the clunk when stopping as the box goes from 2nd to 1st is gone.
It is also worth getting a dealer to reset the adaption data in the gearbox controller if you can. This made further improvements. I bought car at 83000 miles, and it would take ages to relearn my driving style if ever at all.
Sealed for life is a joke :mad: and a bad one at that :( I have no idea what they were trying to achieve in the first place :( other than increased revenue through new gearboxes :(
Evening John :D, I go on the basis that everyone makes a mess of something at some time. The test of character is recovering the situation. At worst the guy has learned how to change oil on an SL box. Next time he will get it right. Given that he had three Mercs in when I went there first time, and today had 1 merc and 5 jags. He is getting this trade on these cars for a reson.
How did you change the filter then? :confused:
adam
7.5 Litres is the correct amount including draining the torque converter.
When checking the level have the gearbox HOT as the level does rise. Drive the car for a mile or two in low gear, after a 10 min drive, to get the gearbox hot.
Peter
It sounds like the gearbox was overfull, possibly because the level was checked cold, not hot.
To check the level the dealers use a Star diagnostic to check the ATF temp. A good rule of thumb is a 10 min drive then a couple of miles in low gear.
The box shouldn't be harmed by the level being too high as there is a float between the sump and the workings. If the level is too high the float seals the opening to keep oil out of the clutches.
good info would be nice to see pics next time some body changes atf
We didn't this time because two of the fasteners on the bottom casing were seized on and we couldn't risk putting the car out of action over the weekend whilst waiting for new ones.
OK thanx :)
