Dec 24, 2009 #1 A amolak Active Member Joined Mar 22, 2003 Messages 275 Car B200Turbo & V350 Hi, What other CD changers can I install directly in my W220 s-class. I currently have: MC3198 A 002 820 7989 Thanks
Dec 24, 2009 #2 Howard MB Club Veteran Joined Apr 23, 2004 Messages 18,624 Location Toad Hall Car 2018 C63 Wagon / CLK430 / A150 / VW Pink Floyd Golf Cabriolet I think the MC 3010 is compatible with the 3198
Dec 24, 2009 #3 OP OP A amolak Active Member Joined Mar 22, 2003 Messages 275 Car B200Turbo & V350 Hi, I take it that the 3010 is an older model. Are there any newer models that will fit. thanks
Dec 24, 2009 #4 proser Active Member Joined Nov 29, 2008 Messages 753 Location Stafford Car W210 E320Cdi Estate The MC3010 and the MC3198 are both the same, other than the MC3010 is slightly shorter for mounting in the glovebox. As you have a MC3198, then you will need to keep to the same, as it's D2B. The later ones are MOST and no compatible. HTH Mark
Dec 31, 2009 #6 H harry halford Member Joined Nov 22, 2009 Messages 41 Location kent Car s class i have a becker 2662 in my s class does anyone know if others will fit thanks
Dec 31, 2009 #7 H harry halford Member Joined Nov 22, 2009 Messages 41 Location kent Car s class hi i have a becker 2662 in my s class its packed up do you know what others will fit asi have tried to replace it but cant find a becker many thanks [email protected]
