CD Changer unit
MercuryRising
Aberdeenshire
Mercedes C Class 180
I have just acquired a 1997 C Class 180 which has a radio/cassette player. This has the facility to control a remote CD changer unit. The car does not have one fitted currently.
How can I identify which is the correct unit for this vehicle and what is the availability?
Where would the unit be fitted?
Is it possible to fit an alternative radio/CD player if the CD changer unit is not available.
I would really appreciate any help with this.
Andy
Hi Mercury rising, it is easier and cheaper to fit an alternative radio/cd player as there would be no wires behinde your radio system to connect the cd changer unit . If you give merc a call they will be able to tell you which models are available to fit your car. You can also contact braybrooks on 01438840800,command europe on 01276474900 and star tech on 01202694758 and they can give you a quote. Hope this helps.
Cheers.
CD Changer
Hi Benzreg,
Thanks for the info.
I have found some secondhand CD Changer units on Ebay.
Some have the connecting cable too.
It may be easier as you say to fit a replacement Radio/CD player.
Will check out the info you supplied.
Regards
Andy :-)
