When I bought my CL the cartridge was stuck in the stacker, and I found this cure on the net:
While holding the button down, tap the cartridge smartly with something wooden - I used a chisel handle. Noone was more suprised than me when it worked.
Your responsibility, of course. When it screwed up again, I sent the whole unit to a firm advertising on eBay, who fixed it for a flat fee of £75. They sent it back with the discs that had been in the cartridge with a note to say DON'T use copy CDR's made on a PC. It cost me good money to replace the copies with legit ones, but didn't go wrong again.
IT WORKS!!!! SOLVED, INDEED :bannana:
I mean that tapping thing ("tap the cartridge smartly with something wooden - I used a chisel handle.") really worked. I did NOT believe it would work, really. So there I was, anyway, hitting/tapping the glove-box-mounted CD changer cartridge with a wooden chisel handle. And voilà, the stuck cartridge came out just like that.
My steps:
- first I took the fuse out, and put it immediately back again. This resets the CD changer, before that fuse trick the CD player´s display just said something like "no CD changer" or something, and the eject-button was not even trying to eject the cartridge. So the fuse trick is needed if your eject-button is not working.
- if I remember correctly (I did this the day before yesterday) the fuse was number 64, a 10A fuse. That fuse should be the one for RADIO, COMMAND system (?).
- the fuse box was the one located in the engine compartment (W203 C-model station wagon). In that fuse box the #64 10A fuse was located in the far corner that is the nearest to the driver, actually.
- then I turned the starter key to the first position, put the radio ON, selected CD, pushed the eject-button on the changer in the glove box... nothing happened.
- but I was ready with the wooden chisel handle and I tapped/hit the CD changer´s cartridge acouple of times when the eject-button was pressed ---> tadaa: the cartridge came out just like in the movies.
To say I was surprised is an understatement, heh.
