Changing tandem pump to a single pump.
Virgovirgo71
South london
Mercedes SL R230 BRABUS B11
Hello all. I'm taking out all the ABC components and replacing with a coilovers conversion. So all out, blocks, hydraulics, hoses the lot! I'm replacing with a SL350 suspension with sway bars included. Basically my SL500 B11 Brabus will have the same suspension as a SL350. We've worked out the weight variable and there's not much difference. The ABC will be deleted via star. So no error messages. My question is this. The high pressure hose that goes from the tandem pump to the steering rack is the problem or is it? The single pump part number 0024668701 looks like it has a different fitting but I've been told that the fitting although looks different will fit. So basically will the high pressure hose on the tandem pump fit directly onto the single pump?
Many thanks
