Circulation switch for 201
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
Heeeeeelp, I am trying to find a recirculation switch for a W201. Tried the dealers and am not prepared to spend over £50 for on. Anyone got a spare they don't need?
Thanks in anticipation
Ian
(tightwad)
I take it this is for a car with air con?
Will
not sure of the part number as it is in my garage ATM
I can probably help but will need a bit more info so if you can get a part number that would be good.
W201 with air con... not going to be too many around..
Part number required A1268202110 also fitted to 560SEC and cars of that age.
The part number has changed to A126 820 51 10 and retails at £48.00 so you should get some discount from that. Unfortunately I do not have that one available sorry.
I've got one. PM sent.
And so has the part. The one I am after has a different pin set up and as I said earlier I am not, or should I say, my customer (a forum member) is not prepared to pay that. Apart from which they are on backorder, so thats another 3 days lost when said customer wants his car back asap. Sorry if this has come out wrong and bitchy, but under a little pressure ATM
Ian
Thanks Niel, pressure relieved :bannana::bannana::bannana:
