OrsonCarte
- Aug 9, 2017
- CL500
2001 CL500 63,000 miles 722.6 5-sp transmission.
Your expert advice appreciated.
My CL500 occasionally sticks in lowest (2nd?) gear.
I know when it's about to happen because the selected gear displayed on the dashboard display (next to the time) displays 'D' no matter which position the gear selector is in. The S/W button display is also inoperative.
Turning the ignition off and back on again solves the problem....for a while.
On the last occasion it occurred, I immediately parked the car and obtained the following diagnostics from the iCarsoft MBII scanner:
P1856 - shift lever position identification failure
P240C - the selector lever position sent from control unit N15/5 (electronic selector lever module control module) via the CAN bus is implausible
P2600 - circuit 87 voltage too low
Datastream - selected gear by means of selector lever (CAN) implausible
After turning the ignition off and back on, checking that the gear selector display was back to normal and rerunning the diagnostics, none of the above warnings were generated and I could continue driving as normal.
I have confirmed that the battery is good with a multimeter. The transmission fluid levels are absolutely spot on and the fluid is a brown-gold colour with no trace of burning. I have also confirmed that the kick-down switch is not sticking.
Besides this occasional glitch, the car runs like a dream. The problem appears to be sensor-related and the car has got previous in this department having displayed several erroneous error messages in the past.
I would be very interested to know if anybody has seen an identical set of symptoms and has identified the specific issue. I am reluctant to pull out the electronic gear selector mechanism when I don't really know what I am attempting to fix. Although I am still mobile, it is a little nerve-wracking not knowing when it is going to happen next.
Thanks in advance.
Thanks in advance.
