Cla200 724 transmission swap
alanmo
Cardiff
Mercedes cla200
Hi all i have a Mercedes cla200 2014 1.8 diesel automatic with the 724 gearbox and I’m looking to swap out my gearbox for a used one and so I am hoping someone can help with a couple of things.
I am hoping with the correct gearbox that I can simply swap out my original TCU into the used one and away i go into the sunset.
I can get hold of one with exact part number
A2463708602
But the (what I think) gearbox code is slightly different…. Mine is 724003 and the used one is 7240022. Also the used one is from a 1.6 petrol and mine is 1.8 diesel.
Please can anyone confirm anything here.
Would be greatly appreciated.
Will add picture of my original gearbox numbers.
You'll need to use a replacement transmission with the same code as your current one (724.003). You'll have issues using a different code.
I doubt the petrol one will fit a diesel as the mating holes beween the transmission and engine are almost certainly in different places.
What's wrong with your current transmission?
It may well be cheaper to refurbish the gearbox you already have.
Thanks buddy my original dual clutch is gone and Mercedes wants extortionate amount to replace and apparently you need a special tool to change dual clutch that only Mercedes have.
If I could get one with the same code 724.003 then would i be able to just swap original conductor plate with TCU to the used gearbox and it will work? Thanks
