Hi all
I noticed a small leak on the drive under the engine and know that it is diesel. I took the engine cover off and although very clean I can see that where the injectors sit there is some small build up of diesel. ( I cleaned it up with some paper towel and it’s completely clean liquid, no Black Death carbon build up). Ive also noticed that the back 2 injectors are worse with the front one having no diesel around it.
I’m thinking it’s the little fuel return lines that clip into the injectors that maybe leaking but I can’t see anything actually leaking. The tops of the back 2 injectors do appear to look a little damp though, would this suggest it could be the return lines? Causing the top of the injectors to seem damp?
Maybe completely unrelated but I have what sounds like a noisy fuel pump, gurgling sound with the ignition on but not started. I’ve read a few posts mentioning this and people had resolved it by replacing the return lines. Apparently if the small o rings go then it lets air into the system via this point causing the noise.
Any help or experience of this appreciated
