Clk windscreen washer reservoir.
D2028
Northern Ireland
2009 CLK 220 cdi avantgarde, 2004 landrover discovery2 td5
I only seem to use the windscreen washer very occasionally but the low fluid warning comes on very quickly. I don't see any obvious signs of leaks so before I start removing stuff has anyone noticed this before, or are there any common weak points in the system.
I have headlight and windscreen washers and all are working perfectly, I just seem to be topping up fluid more often than normal.
I seem to recall having a similar problem (but not on a MB) Turned out to be a cracked feeder pipe into the tank. If I remember was cheap to simply replace the tank, HTH
It's not an urgent or critical problem but I'll have a closer look when the weather picks up again and then start gathering up parts. Hopefully it's something as simple as a grommet.
Might be the small pump O rings down behind the wheel arch liner .
Assuming you're referring to the grommets the pump mounts to the here's hoping that's all it is.👍
