Mini
Hi, I am new to the forum (2001 w208 CLK320 Coupe). Have seen a few posts relating to transmission issues, but most of them mention 'limp mode', but I don't think the problem I have really causes the 'limp mode' to activate.....yet!
The car has become very sluggish over the past 4-5 months
, and initial thoughts were MAF, so replaced this; but no effect. When I realised that the MAF had no effect, I started looking more closely at how the car was revving etc, and noticed that it consistently 'over-revs' slightly before you get the actual acceleration from the car and the problem is getting progressively worse to the point where I have to kick-down a lot of the time just to get some decent power out of the car, which is obviously having a negative effect on the fuel economy. Also the timing of the gear shifts also seems a bit erratic at times.
During a recent 'B' service at a local specialist, I had them do a FULL diagnostic, but no fault codes came up. The mechanic after driving it said he suspected a dodgy 'electronic plate / conductor plate' (whatever the right terminology is!).
Could the leak, which went un-noticed for a couple of weeks, have had an effect on the conductor plate in any way? and has anyone been through this before?
Plus, does anyone know any decent independents around the Bracknell/Sandhurst Area?
I had the 'B' service done at Mercs Only in Hanworth cos its close to work.
