CLK320 Drain Holes
s8wrd
Cardiff
CLK320
Hi All....Anyone know where the drain holes are on a CLK (2004) ?...I've got water pooling under the fusebox, brake fluid area ... there's a silver pipe that gets hot in operation and i believe causes the standing water to steam, and condensation enters the fuse box lid....its an obvious water route as the cover directs water there, but I can't seem to see any drain hole....could it be I need to view from underneath, inside the wheel arch cover ?
Hi All....Anyone know where the drain holes are on a CLK ?...I've got water pooling under the fusebox, brake fluid area ... there's a silver pipe that gets hot in operation and i believe causes the standing water to steam, and condensation enters the fuse box lid....its an obvious water route as the cover directs water there, but I can't seem to see any drain hole....could it be I need to view from underneath, inside the wheel arch cover ?
From memory there is one in the middle of the scuttle and one (or two) towards the outside edge by the wing. Hopefully someone will be along soon with a better description.
