Rabk
I am at a loss to find the drain holes on my 2013 e220 cdi w212 pano roof. I poured water in the channel on the drivers side with the roof open and it seems clear, the water exeted from behind the front wheel behind the wheel arch onto the ground. The pipe on my nearside must be blocked as when it rains there is dampness coming down the door pillar. I have checked underneath at the nearside wheel arch and there is no pipe anywhere in the wheel arch as I had the wheel off and the wheel arch removed. The only drain there was the
bulkhead which is quite large. Maybe the drains come down the door pillar and somehow exit at the bottom of the pillar into the bulkhead drain, only a thought. I will check this tomorrow. Fingers crossed. I phoned main dealer for help, still waiting for reply, not hopeful.
Can you help?
Can you help?
