cls airmatic malfunction warning
daniel200
bedford
2007 cls 550
i have a 2007 cls500 and just this morning the warning sign came up on my dash ( car with arrow pointing upwith malfunction under )
the car drives ok maybe a little wobbly even in sport 2 mode, i stopped and checked all 4 wheels and looked normal started back up and warning went away .
I left the car for a few hours and the checked to see if it raised and lowered which it did fine,shut it off then went to restart it and warning sign came back can anyone help
Welcome to the forum Daniel.
You really need to take the car to a Mercedes Indy and have a Star test done on the airmatic system. If your airmatic pump is struggling, it can quickly burn out.
You may have a small leak in one of the airstruts or valves. The Star test will determine what the exact problem is.
These two links may help understand the problem.
You are being redirected...
Thanks for your reply I am taking it to a garage Monday to get sorted hoping it’s an easy fix !!
