cls window and door seals
graham964
mercedes cls 320cdi
Hi
I have just bought a cls and I have noticed that the tops of the seals which the window runs in are split at the top. If I wanted to replace them would I need to remove the door card or can the seal which appears to go all around the doors be replaced without removing the card. Any advice gratefully received.
cheers
Graham
They can be replaced without removing the door card but you need a set of
trim tools which you can get from Eurocarparts
Hi
could you say what these trim tools are
Graham
