Colour Code
KY 200
Hi Guys,
I'm having trouble finding the colour code for the bumper moulding on my W210 , all I can get is 744 , the body colour (brilliant silver) and no secondary trim code. The colour I need is almost graphite . A new moulding comes unpainted ,so there must be a number for it.
Cheers
The other colour is available from the car's datacard on the EPC, it will list a second colour code. If you PM your VIN to me I can look it up for you, or you could call your stealership and they can do the same thing :)
The datacard doesn't list a second paint code, but when I looked up the part numbers for the detachable strips on the side of your car it came up with a second code:
181 - Stratus Grey
When I looked up the part number for the bumper it came back with:
181 - Atlas Grey
Same code, different name! If you want to order a pre-painted part with that code then it's listed as 7181, for example if you wanted to order the little plastic strip on the front wing then it's:
A2106901362 7181 : LEDGE : EUR 18.46
Let me know how you get on!
I should add that the W202 in 744 also has the 181 paint code on the other-toned trim pieces, as confirmed by Sym's old car's VIN :)
