I have W212 E350 2011 avantgarde model with Comand. I am currently in Italy on holiday and have a small problem and am seeking advice as to the best fix.
The Comand controller knob located between the front seats works when using the slide function but does not work when using the control wheel turn function. I can use most of the options using the slide function but am missing some key functions, such as changing map scale and zoom.
I have checked the manual and can do a full reset to factory spec but in doing this loose all the saved locations data etc. If possible I would like to avoid this.
I will also need Comand for the journey home of over 1000 miles so don't want to create a problem for the return
I am unsure if it is a hardware or software problem. If it is likely to be software is there a simple "reboot " procedure that might help.
Any help and advice would be appreciated
