Command APS NTG4 question?
This Item is just for a repair of your Sat Nav...
1. Would you be able to install maps for Singapore/Malaysia/Thailand?
You should be able to Install those maps on your current Sat Nav, else you could change your Navi into ECE or US through the Secret Menu of NTG 4
2. Can the iPod work as I have media interface installed in current system?
Should work as usual
Thanks bro...
Can I go ahead and buy this so that I can discard my current Japanese HU as it is impossible to hack the system to work to my country..(Malaysia)
I am looking for retrofitting my Comand APS NTG4 on my C200 CGI (2010 model-japan specs)
As this system I have now cannot work on GPS/Radio/iPod even after changing to ECE mode, I have to fit a unit which can do all.
Please advise the spare part no. for my ride to do this retrofit...
It seems like you have a different Radio system than we do have here in Europe, did you have check out if any local Benz Forum would maybe have some people already tried or did this conversion? Let us know if you should find a solution. The other option is to check on a W212 NTG4 which would also be able to get to work in an W204 with minor fascia modification.
Do you have the iPod Interface or Media Interface Kit already installed in your car and activated?
I tried local guys.. the price they quote is arm and leg
The iPod interface / media interface is already there with 3 MB cables for aus, ipod and usb
So you have iPod USB from factory and still you can't use them? What is your local Merc Dealer saying about iPod not working?
Btw send me the part number of your ntg4 so I can compare to mine once I got time to take it out.
Local dealers are Cycle & Carriage.. totally hopeless !!! they have no idea for this :(
I will post it later here
