Exactly the same as mine. Did the trick with swapping the wires and the fault stayed with the passenger side, so the duovalve was duff.
Got one from eurocar parts for about £110 +VAT. Fitting was relatively easy once you know how the underneath clips fit, which is apparent when you get the new one out of the box. Be careful as it is possible to 'ping' the clips off especially when putting them back, and they can go into very awkward places. I actaully tied mine on while fitting as I nearly lost one down the back of the brake servo. Once you have figured the clips out, it is literally a push on fit. The hoses to the top of it have to be removed obviously, but you can do it without draining the system as long as you don't mind a bit of water in the engine bay. Take care to protect the air filter/box from water as you don't want water in there. With care it will probably take about 30 mins to do. When complete, run the car with the heating on full and squeeze the top hose for a few minutes to remove any air that might have got in.
This is how I did it. Others may have a more professional approach to the job!
